CPUID HWMonitor Report
Binaries
HWMonitor version 1.1.7.0
Monitoring
Mainboard Model A785GM-AD3 (0x0000025E - 0x137A0D98)
LPCIO
LPCIO Vendor ITE
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8726
LPCIO Revision ID 0x3
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Register space LPC, base address = 0x0E80
Hardware Monitors
Hardware monitor ITE IT87
Voltage 0 1.04 Volts [0x41] (CPU VCORE)
Voltage 1 1.15 Volts [0x48] (VIN1)
Voltage 2 1.58 Volts [0x63] (+3.3V)
Voltage 4 5.06 Volts [0x4F] (+12V)
Voltage 5 -9.98 Volts [0x9C] (-12V)
Voltage 6 -9.98 Volts [0x9C] (-5V)
Voltage 7 5.40 Volts [0xC9] (+5V VCCH)
Voltage 8 3.10 Volts [0xC2] (VBAT)
Temperature 0 29ฐC (84ฐF) [0x1D] (TMPIN0)
Temperature 1 44ฐC (111ฐF) [0x2C] (TMPIN1)
Temperature 2 46ฐC (114ฐF) [0x2E] (TMPIN2)
Fan 0 975 RPM [0x2B4] (FANIN0)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 75 pc [0x60] (FANPWM1)
Fan PWM 2 75 pc [0x60] (FANPWM2)
Hardware monitor ACPI
Hardware monitor AMD ADL
Voltage 0 1.05 Volts [0x419] (VIN0)
Temperature 0 52ฐC (124ฐF) [0x33] (TMPIN0)
Processors
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name AMD Athlon II X2 250
Codename Regor
Specification AMD Athlon(tm) II X2 250 Processor
Package Socket AM3 (938)
CPUID F.6.2
Extended CPUID 10.6
Brand ID 13
Core Stepping DA-C2
Technology 45 nm
Core Speed 798.3 MHz
Multiplier x FSB 4.0 x 199.6 MHz
HT Link speed 1995.8 MHz
Stock frequency 3000 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
FID range 4.0x - 15.0x
Max VID 1.400 V
P-State FID 0xE - VID 0x0C - IDD 23 (15.0x - 1.400 V)
P-State FID 0x7 - VID 0x14 - IDD 20 (11.5x - 1.300 V)
P-State FID 0x2 - VID 0x1C - IDD 19 (9.0x - 1.200 V)
P-State FID 0x100 - VID 0x28 - IDD 8 (4.0x - 1.050 V)
Package Type 0x1
Model 50
String 1 0x3
String 2 0x6
Page 0x0
CmpCap 2
TDP Limit 62 Watts
TDC Limit 46 Amps
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 0200400Bh
Max CPUID level 00000005h
Max CPUID ext. level 8000001Bh
Cache descriptor Level 1, I, 64 KB, 1 thread(s)
Cache descriptor Level 1, D, 64 KB, 1 thread(s)
Cache descriptor Level 2, U, 1 MB, 1 thread(s)
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 0200400Bh
Storage
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x04D9, product=0x0001
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x1D57, product=0x0A02
USB Device D-Link Wireless G DWA-110 USB Adapter, class=0x00, subclass=0x00, vendor=0x07D1, product=0x3C07
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
Name ATI Radeon HD 4770
GPU ref clock 27000
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1787)
Model ID 0x94B3 (0x2280)
ACPI
Copy เฉพาะอันที่จำเป็น พอดีถ่ายรูปไม่เป็น
*** เรื่องไฟที่มันเพี้ยนๆนี่มันเกี่ยวกับ MB มั้ยคับเคยได้ยินว่าถ้าบอร์ดถูกๆจะใช้ไฟไม่เต็มที่ -*-
ขอบคุณครับ ผมงงมานานแล้วคับ ช่วยที
Binaries
Monitoring
LPCIO
LPCIO Vendor ITE
Config Mode LDN 0x4
Hardware Monitors
Processors
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processor 1 ID = 0
Codename Regor
CPUID F.6.2
Extended CPUID 10.6
Brand ID 13
Core Stepping DA-C2
Technology 45 nm
FID/VID Control yes
Max VID 1.400 V
Package Type 0x1
Model 50
String 1 0x3
String 2 0x6
Page 0x0
CmpCap 2
TDP Limit 62 Watts
TDC Limit 46 Amps
Thread dumps
CPU Thread 0
APIC ID 0
Type 0200400Bh
CPU Thread 1
APIC ID 1
Type 0200400Bh
Storage
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
GPU ref clock 27000
ACPI
