เช็คHard disk Error ในhd tune proแล้วได้แบบนี้ แปลว่ามันมี BAD ใช่ป่าวคับ
  • เช็คHard disk Error ในhd tune proแล้วได้แบบนี้ แปลว่ามันมี BAD ใช่ป่าวคับ
    HD Tune Pro: ST3500320AS Error Scan
    Scanned data : 465 GB
    Damaged Blocks : 2.8 %
    Elapsed Time : 120
    1 Error at 3008 MB (LBA 6160893)
    2 Error at 3078 MB (LBA 6305712)
    3 Error at 3541 MB (LBA 7253398)
    4 Error at 4428 MB (LBA 9069717)
    5 Error at 8490 MB (LBA 17388228)
    6 Error at 9613 MB (LBA 19688054)
    7 Error at 10002 MB (LBA 20486108)
    8 Error at 17539 MB (LBA 35921825)
    9 Error at 28775 MB (LBA 58931554)
    10 Error at 38726 MB (LBA 79311038)
    11 Error at 38770 MB (LBA 79401329)
    12 Error at 42739 MB (LBA 87530656)
    13 Error at 44518 MB (LBA 91173611)
    14 Error at 44695 MB (LBA 91536542)
    15 Error at 46434 MB (LBA 95097065)
    16 Error at 46680 MB (LBA 95600668)
    17 Error at 47080 MB (LBA 96420738)
    18 Error at 47558 MB (LBA 97399707)
    19 Error at 48615 MB (LBA 99564186)
    20 Error at 48648 MB (LBA 99631821)
    21 Error at 48973 MB (LBA 100298112)
    22 Error at 50242 MB (LBA 102896741)
    23 Error at 51553 MB (LBA 105581642)
    24 Error at 52517 MB (LBA 107556425)
    25 Error at 60814 MB (LBA 124548442)
    26 Error at 100627 MB (LBA 206085885)
    27 Error at 112828 MB (LBA 231072189)
    28 Error at 115192 MB (LBA 235914017)
    29 Error at 139204 MB (LBA 285090107)
    30 Error at 142260 MB (LBA 291350507)
    31 Error at 142401 MB (LBA 291638302)
    32 Error at 142576 MB (LBA 291995857)
    33 Error at 142735 MB (LBA 292323204)
    34 Error at 143020 MB (LBA 292905783)
    35 Error at 143244 MB (LBA 293364714)
    36 Error at 143306 MB (LBA 293491869)
    37 Error at 143574 MB (LBA 294040656)
    38 Error at 143875 MB (LBA 294656438)
    39 Error at 144100 MB (LBA 295117929)
    40 Error at 144265 MB (LBA 295456412)
    41 Error at 144457 MB (LBA 295848143)
    42 Error at 144904 MB (LBA 296764213)
    43 Error at 144990 MB (LBA 296939752)
    44 Error at 145931 MB (LBA 298866996)
    45 Error at 146711 MB (LBA 300465843)
    46 Error at 147088 MB (LBA 301236633)
    47 Error at 147867 MB (LBA 302832997)
    48 Error at 148510 MB (LBA 304150270)
    49 Error at 148889 MB (LBA 304925668)
    50 Error at 149946 MB (LBA 307089635)
    51 Error at 150066 MB (LBA 307336342)
    52 Error at 152127 MB (LBA 311556551)
    53 Error at 168249 MB (LBA 344575875)
    54 Error at 168351 MB (LBA 344784566)
    55 Error at 174502 MB (LBA 357381526)
    56 Error at 174738 MB (LBA 357864649)
    57 Error at 175101 MB (LBA 358606895)
    58 Error at 175230 MB (LBA 358871138)
    59 Error at 178113 MB (LBA 364775775)
    60 Error at 180733 MB (LBA 370142377)
    61 Error at 181022 MB (LBA 370734684)
    62 Error at 183190 MB (LBA 375173696)
    63 Error at 238477 MB (LBA 488401414)
    64 Error at 264844 MB (LBA 542402308)
    65 Error at 265647 MB (LBA 544046928)
    66 Error at 266139 MB (LBA 545053161)
    67 Error at 266608 MB (LBA 546015055)
    68 Error at 266794 MB (LBA 546394242)
    69 Error at 267098 MB (LBA 547017832)
    70 Error at 267320 MB (LBA 547472155)
    คือเรื่องมานเป็นแบบนี้น่ะครับ
    ก่อนหน้านี้2-3วันไฟบ้านผมมานตก 2 รอบอ่ะครับ แล้วรีสตาตมามานก็ขึ้นให้สแกนดิส(win 7)
    สแกนค่อนข้างนานเลยอ่ะ
    พอมาถึงมะวายตอนเย็นฮาดดิสมานค้างไปเลยอ่ะแบบว่าเห้นไดร์ฟน่ะครับแต่ทำอะไรกะข้อมูลไม่ได้เลยกดเข้าไปสักพักก็ค้างผมเลยเชคสายไฟดู ซึ่งตัวนี้ผมใช้สายแปลงไฟsataเลยลองเปลี่ยนดู แล้วมันก็กลับมาใช้ได้
    ผมเลยเริ่มแบ็คอัพแต่ทีนี้ผมเจอหลายไฟล์เลยครับที่ก็อบไม่ผ่าน ผมเลยใช้โปรแกรมเช็คดูมานได้แบบนี้อ่ะ สรุปมานเป็น bad ใช่ป่าวคับ
    แล้วจะดูยังไงครับว่ามานเป็น badจริง badหลอก
    เป็นแบบนี้ผมเคลมได้ใช่ป่าวครับเพราะประกันผมยังเหลืออยู่
    แล้วผมไปหาข้อมูลมาเวลาเช้ค bad หลอก ให้ให้ FDISK ลบ Partition ทุกตัวทิ้ง แล้ว FDISK สร้าง Partition ใหม่ แล้วลอง Format แบบไม่ Quick ถ้าหาย แสดงว่า Bad หลอก มานถูกต้องไหมอ่ะครับ
    แล้วFsidk ยังไงอ่ะ ขอวิธีทำด้วย
    ใครมีวิธีแกวิธีอื่นแนะนำผมด้วยน่ะครับ ขอบคุณครับ
    เครมเถอะครับ ขากลับอย่าลืมซื้อเครื่องสำรองไฟด้วยนะ
      ขอบคุณครับ คืออยากเครมแล้วได้ของใหม่ไปเลยอ่ะเลยกะจะดูให้แน่ใจก่อน
      ส่วนเครื่องสำรองไฟตอนนี้ก็คิดว่าจะซื้อแล้วล่ะครับแต่ต้องเชคดูเงินก่อนอ่ะ
        ไปหาupsโดยด่วนและอย่าลืมเคลมhddนะ
          อีกอย่างลองFormat hddดูก่อนเพื่อเป็นbadปลอม
            Format ผ่าน disk management เลยๆด้ป่าวครับหรือต้องผ่านdos
            ตอนนี้กำลังแบ็คอัพไฟล์ออกมาอยู่ เด็วเสร็จแล้วจะลองformatเลย
              ไม่รู้นะแต่น่าจะ Format ผ่านอะไรก็ได้ขอแค่ไม่ควิกก็พอ(Formatทั้งลูกนะ)
