ผมอยากทราบว่าเมนบอทรุ่นนี้ใช้การ์ดจอ DDR ไรได้มั่งหรือแค่ DDR2 อย่างเดียว
แล้วใช้ CPU รุ่นไหนดีถึงจะแรง แบบจะเอาไปเล่นเกมช่วยจัดสเปคให้หน่อยคับ
CPU ? LGA775 socket for latest Intel? * Wolfdale/ Core?2 Duo /Pentium Dual Core/* Pentium D / Celeron 4 xx series/ Celeron D Processors
? FSB 1333*/1066/800/533 MHz
? * 945GCT-M2/1333 v1.0A is capable to support Wolfdale processor through BIOS update. Please refer to BIOS download
? * This board is ready to support Intel? Pentium D and Pentium 4 processors
? *Supports FSB1333 processors through H/W and BIOS modification.
CHIPSET ? Intel? 945GC & ICH7
? North Bridge: Intel? 945GC
? South Bridge: Intel? ICH7
GRAPHICS ? Integrated Intel? Graphics Media Accelerator 950 ( GMA950 )
? Max Dynamic Video Memory up to 224MB(System Memory greater than or equal to 512MB)
MEMORY ? Dual-channel DDR2 memory architecture
? 2 x 240-pin DDR2 DIMM socket support up to 2 GB
? Support DDR2 667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows? 32-bit OS.
For Windows? 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT ? 1 x PCI Express x16 slot
? 2 x PCI slots
STORAGE ? Supported by Intel?ICH7
? 2 x Ultra DMA100/66 devices
? 4 x Serial ATA 3.0Gb/s devices
AUDIO ? IDT 92HD202 6-channel High Definition Audio Codec
LAN ? Realtek RTL8100C 10/100 Mbps Fast Ethernet Controller
REAR PANEL I/O ? 1 x PS/2 keyboard & PS/2 mouse connectors
? 4 x USB ports
? 1 x VGA port
? 1 x Serial port (COM1)
? 1 x RJ45 LAN connector
? 1 x Audio port (3 jacks audio phone)
INTERNAL I/O CONNECTORS & HEADERS ? 1 x 24-pin ATX Power Supply connector
? 1 x 4-pin ATX 12V connector
? 1 x FDD connector supports one 360K~2.88MB FDD
? 4 x Serial ATA connectors
? 1 x IDE connector
? 1 x SPDIF out header
? 2 x USB 2.0 headers support additional 4 USB 2.0 Ports
? 1 x Clear CMOS header
? 1 x Front panel header
? 1 x Front panel audio header
? 1 x CD in header
? CPUFAN/SYSFAN connectors
SYSTEM BIOS ? AMI BIOS with 4Mb Flash ROM
? Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
? Supports ACPI revision 1.0 specification
FORM FACTOR ? Micro-ATX Size, 244mm*200mm
Awards
? 2 x PCI slots
? 4 x USB ports
? 1 x VGA port
? 1 x IDE connector
? 1 x CD in header
Awards
